I'm useing a Arjen Helder's TA2024 module, and I would like to know if I can use a power adaptor wich I had from my old computer.
Arjen's module requires 12V 2 or 3Amp power.
I have this adaptor: Hahnel Innovative Accessories
Can I use this??
it says "automatic output voltage setting 12V-22V 5A (90W)"
Will tjis burst my amp if I conect it? or should I buy a specific adaptor?
thanks for the help 🙂
I will delete the other thread in "class d" wich is the same as this one😱
Can I use this??
...it says "automatic output voltage setting 12V-22V 5A (90W)" Will tjis burst my amp if I conect it?
I looked at the link, but I can't tell from what is written there how the 'automatic output voltage setting' works, so unless someone comes on who actually has one of these adaptors and can definitely say it's OK, I think you should NOT connect it to your amplifier, it's a risk.
w
