Pair of Ale Moglia Gyrator boards build by Ale and used by me for short time in triode 26 line stage.The top mosfet is IXTP08N50D and the second is BSH111.
The capacitor is Amtrans Gold Black Aluminium oil foil 100nF.
Bouth boards working perfectly and were stored now for almost 4 years.
Price would be 160 euro including tracked shipping inside EU or best offer!
You can use this boards with many diferent old triodes like 26,01a,76,56.....and with some new one also.You can use the boards like gyrators or ccs,you can use
BSH111 output for low output impedance or normal anode output.This boards are designed for build a line stage,tube pre,phono amp or some other project,but of course limiting factor is max.input voltage and needed current. Good to up 50mA of bias current and up to 450V of B+ voltage!
For more info look on Bartola online site and projects that Ale meade with this boards.
Hi,no.You can use this emidetly for 01a preamp or 26 triode preamp,like I have.This boards where made exactly for this two typ of triodes😉
