i want to add a tube buffered effect loop to a band master. there are a lot of kits, but im just going to do my own. i wanted to know if the power transformer can handle another 12ax7 without any issues? all the kits dont specify whether you need to make a separate supply or upgrade the one in the amp.
PS and the heater of one extra 12ax7 probably adds only a few % to the total wattage the PT would normally need to supply. Why would you need to use a loop on that amp? I wouldn't think the 2nd stage of either preamp distorts. Maybe you have a line-level rack setup?
its not my amp, but yes a lot of rack fx and emulators, will be used as a studio amp. i wouldnt touch a vintage fender of my own for anything, they should be left as is, but its not my amp, thanks jjman
