Banana Plugs for under $20 from Ebay ?
Can anyone recommend Banana Plugs for under $20 from Ebay ?
I see Nakamachi in this price range not sure if there is a lot of fake stuff sub-$20.
Just something that will shield effectively... a kind of go-to no frills quality set basically.
I know it is not a lot of money but I'm unsure how much you need to spend on them right now... !
I got these recently to use to attach speaker cables to my 4 ar215 PS bookshelf speakers, and a bic venturi dv32clr center (obviously going to have to mod in two female banana jacks on the center) for my 5.1 setup with a pioneer vsx822-k.
http://www.ebay.com/itm/121072830819
Been buying these same plugs for a while now, and they work very good for my needs, are cheap, and while i don't think they would be shielded super good, you could diy something with some mesh tubing or something, depending on your speaker cables.
I put the wire through the back, and tighten them down, which clamps them between the pin in the inside of the plug, and the front of the plug.
Gets a pretty snug/good connection without soldering. Though you could solder it, and it it would be a lot more sturdy/a better signal quality.
DH-Labs Silversonic SP-2W Spade connector 8 AWG 1pair items in audiohobby.eu store on eBay!
DH-Labs B-1C will be enough.
And here is some warning about Nakamichi:
http://www.diyaudio.com/forums/everything-else/210672-warning-nakamichi-plugs-made-iron.html
