Balanced to unbalanced circuit
does anyone knows tested low noise tested circuit? I want updgrade Bmw HIFI Logic 7 amp. Problem is engine noise if I connect direct RCA on TDA8566Q balanced input. So I decide build low noise pream wich will convert balanced to unbalanced signal.
I dont want to use audio processor is too expensive, Hi-Low converters I dont like too (poor audio quality), so I think the best solution make converter.
There is one big problem, preamps using dual PSU in Logic 7 single... Maybe I`am not right cause I get balanced output from digital section to TDA8566Q?
I did some drawings LOGIC7 - Image on Pasteboard
TDA8566Q input impedance 120Kohm by datasheet.
THANK YOU!!
I think I found a solution pls look my drawing. I will add balanced to unbalanced converter ( GHXAMP NE5532 Balanced XLR to Single ended RCA Output Dual op amp circuit board small size low distortion low noise|Amplifier| - AliExpress ) inside aftermarket amp. Maybe I will tune aftermarket amp and do not buy converter, depends what preamp circuit inside. Than power up converter from dual PSU. But now main problem L7 SGND and GND is the same signal. In aftermarket amp SGND and GND are separate signal lines, I`am confuse what I should to do...??? It will get huge interference...
My drawing: L7 - Image on Pasteboard
