Hi, i had just finished my low tim amp (The Leach amp 2x120w 8ohm's, power amp), and
want to build this balanced line stage.
My 1st quistion is - My power amp, has an input impedance about 20kohm, would this be fine, with the line stage ?
My 2. quistion is - does anyone know, if you can use the IRF630, and IRF 9630, instead of the 610 and 9610.
Hope someone can answer my quistion thanks.
