I'm just finishing up with my Odin Mk3 MTM Case, and have decided to redo the baffle before i install it (it was in 3/4 MDF and I wasn't very happy with the thickness or the precision of the circles).
I was considering using a 1 inch thick real wood baffle, so that the roundover-edges would have some nice grain and be stainable (MDF rounds ok but looks like crap next to rosewood veneer, unless i'm doing something wrong...)
BUT: someone mentioned that using a sold wood baffle would negativly effect the sound (resonance?). Is this the case?
What is an ideal baffle, given that I dont want to have exposed MDF roundover-edges if possible. (Alternately, if I must have these edges, is there a good way to give MDF a solid black color? What sort of point will sit on it? - it just soaks everything up 😛)
Thanks!
Thanks!
those people who claim real wood sounds worse than MDF never tried or did it wrong. I suspect they say so because say managed to buil something box like from MDF once in life.
Go with the real wood if you can do, glue it from some not to big blocks together.
Else use high quality plywood.
Problems with the wood will occure if you use it too thin.
Mmm... You can use a baffle that's 1/2 solid wood, 1/2 MDF. Cut the rear layer (MDF) so that it fits into the 4 side walls (when the rest of the enclosure is assembled) without any gaps, and cut the front layer so that it's flush with the outside of the 4 side walls. Then your baffle will be relatively sonically inert, and look good at the same time.
I don't understand the problem with using veneer. Unless the veneer is particularly brittle you can usually veneer over the roundover as well, so it looks like a solid piece of wood. I have heard it stated many many times from many knowledgable sources that using real wood as opposed to mdf with create more audible colorations, so I would be hesitant to try it. Alternatively, if you just want a black baffle you can paint the mdf black, but you should use several coats of primer or sanding sealer first so the mdf won't just soak it up.
Real wood is great but be prepared for a lot of prep work. I used some 4/4 Lacewood (each piece was 5" wide). The planks had to be planed, then glued together so I ended up with a 9" plank just a little over 3/4" thick.
Munroe,
I concur with 454Casull. I have been to see Jim Salk's speakers (www.salksound.com), who I think was influenced by Dave Ellis (www.ellisaudio.com) who uses solid wood baffles. In both cases, the inner baffle is 3/4" MDF. The outer shell is then glued with NoNails or any adhesive which has some flexibility to it so that the wood, when it moves with moisture absorption can expand while the MDF remains relatively the unchanged. Jim Salk applies a 1" x 3/8" hardwood strip around the outside, mitred at the corners. It has a 3/8" roundover. Then he sizes the hardwood baffle so that it fits just inside the roundover. He then rabbets the edge of the hardwood so that it will drop inside the edge strip but no quite contact the MDF baffle. He rounds over the edge of the baffle with a 3/8" roundover, thus producing a modified 3/4" roundover. Then he glues the baffle to the MDF with NoNails.
I have made 5 MBOW1 speakers using Salk's method but they have not yet gone through the winter/dry-summer/humid cycles to see if the hardwood baffles withstand the changes in humidity and stay glued to the MDF inner baffle. But Jim's speakers have done so over at least 2 years without problems. Check out his website.
Fred
Fred
As far as I know the more, different, layers you have the better. Just make sure you have the inner baffle cut away enough to let the back of the driver "breathe." I'm pretty sure the theory behind this is, one: added mass, and two: the different materials have differend resonance frequencies, so they sorta block resonance frequencies for eachother. You could always take it to the extreeme and make a front baffle thats almost 4'' thick and made of 4 different materials.....
I'm putting 4/4 African Mahogany on my Ellis 1801. It looks nice but it's a lot of work. Remember you need to veneer first then put the hardwood on last so the edge of the hardwood is flush with the veneer surface. Clamping it without scarring the solid wood baffle and the veneer on the back was a little unweildy. And when you glue it, baffle side down (so the glue doesn't get on the veneer), the enclosure skates around as you tighten the clamps.
Be careful about chip out when trimming it to fit. The piece you glue over your old baffle shouldn't be more than an 1/8" oversized. I didn't heed this advice and I chipped a corner that I hopefully can fix with the piece that chipped off.
I don't know if I will use hardwood again on a speaker this size when veneering is so easy.
Four 1/4" dowels will line up the baffle for you while you clamp.
One material does not block the resonant frequency of another.
Adding mass may or may not be a good thing, depending on the resonant frequency obtained as a result.
Adding stiffness is almost always a good thing, but might drive a resonance up into a critical band (though amplitude at resonance will be lowered).
There is nothing in MDF that makes it a superior material for speaker enclosures other than (1) easier to predict final stiffness and resonances and (2) easy of workability and dimensional stability. It doesn't "sound" better than natural hardwood.
Damping is beneficial for fullrange or monitor type enclosres (much less so for sub enclosures). Mass added that has a high hysteresis damping can lower the amplitude of resonances.
Joined 2004
To add my 2cents here:
I've been building (for the last 3 months!!!) my kick-a$$ 🙂 active line array using 8 Vifa PL18WO09-04 midwoofs and 6 BG Neo8 PDR tweeters.
This two-way line array is to be crossed-over and parametrically equalized using a Behringer DCX2496.
Of course, this is neither here or there for this thread... 🙂
HOWEVER,
The wood used to build these 150lb monsters is.
The outer part of the speaker is wrapped by an 18mm Baltic Birch plywood (13 ply). ALL wood! 🙂 Rounded over using a 1" radius roundover bit that gives it a nice organic feel...
The reason (well one reason) it took so long to make it's because I decided to sandwich extreme dynamat between the outer plywood and the inner 0.75" MDF.
So, going from outside to inside it goes like that:
LAYER 1) 18mm Baltic birch
polyurethane glue / Titebond Premium wood glue
LAYER 2) Extreme Dynamat
LAYER 4) 3/4" MDF
LAYER 5) Extreme Dynamat
LAYER 6) 1.5" Acoustic "egg-crate" foam
LAYER 7) Acousta stuff polyfill
whew! That was long! 🙂
Anyway, needless to say, this thing is dead, dead, dead...
It took a while but I bet it'll be worth it.
I hope my input was of *some* use to you... 🙂
HOWEVER,
LAYER 4) 3/4" MDF
I have 35 sheets of maple burr 50*30cm each. You are correct is is very nice wood. This cost me £35 on ebay😉 Went and looked at a web site said it should cost £580😱
as much talk as there is here about layering, a "?more important?" factor is effective internal bracing. there are lots of threads about this topic that i would recomend reading (search).
If you want to keep the look of wood, you can "picture frame" the front edges of your cabinet with, say 3/4" x 1" solid wood. Then cut a 1" thick veneered mdf baffle to fit precisely within this frame. Then you can rout whatever profile you like on the solid wood section. Or the wood "picture frame" can be glued around the edges of a baffle, then the whole assembly glued to your existing cabinet
ultrachrome said:...the enclosure skates around as you tighten the clamps.
Just sprinkle a little dry sand over the glued surface and clamp, bingo, no slip 😉
I never thought of that good idea Ill try it
Joined 2004
Chris8sirhC said:as much talk as there is here about layering, a "?more important?" factor is effective internal bracing. there are lots of threads about this topic that i would recomend reading (search).
Chris8sirhC,
I agree with the bracing remark.
However, my project despite its long, errr, length it has only an 8" baffle and the internal width is less than 5". Actually, if you look at it with the foam in place, there's not much space at all (<2"!).
A good knuckle rap anyway on the enclosure produces a very dead sound.
I assure you, bracing is very unnecessary in my design... 🙂
Thanks for all the suggestions!
jbateman: that is a really neat idea that I will definately be trying in the future, and possibly on this project if i can't get the MDF edge as black as I want (going to paint it).
In the end, I've settled with something like this:
a 3/4 inch mdf baffle, in which I will cut the 'inner' hole, with a 1/4 inch mdf piece glued on top, in which i will cut the outer hole (i.e. so that there will be a 1/4 inch recess for flush mounting).
Makes it easier to get a good even depth and flat surface for the flush-mount, and easier to cut overall, since I broke the appropriate (wide) router bit a little while ago and would otherwise have had to make several passes with a smaller one.
Thanks!
Thanks!
- Baffles: Real Wood vs MDF vs Layering
