B1 without output caps
The B1 is AC coupled.
This is because the input operates at a voltage that is not @ audio ground.
and
Because the output operates at a voltage that is not at audio ground.
If your source can drive a high DC voltage input then you may be able to omit the input cap.
If your receiver can accept a high DC voltage input then you can omit the output cap.
If either of these are not the case, then you will break at least one end of your equipment.
A question:
How can you be an active Forum Member for over 3 years and need to ask?
and
Now i understand. Many thanks!!!!
