B1 Preamp - Help Me!
Ebay is your mate.
As for the pot before or after the unity gain circuit, that depends on where you have the weakest situation. 90% of cases is the driving of the interconnects and main amp's input impedance without loss of signal or response deviations.
jacco vermeulen said:
Buy a DMM.
You can pretty much use any cap you fancy, just not the same as a polyprop.
If you're not in a hurry and /or can shortly get by with a crappy, i'm about to order some NOS Wima MKP for 24p per uF, could send you some.
What do you mean by not the same as polyprop?
By the way I found a pair of big electrolytics from a amp several years old. Do you think its safe to use? They might be damaged in some way no?
Found a stylish stabilized one for 15-24V with setting pot, made for laptops, in Maplin. You can use it on your notebook when not listening to B1.
That should be easy to get in London, yes?
Link
