B1 newbie qusestion
I was wondering if I am understanding Nelson's B1 board right as far as
wiring the pots. Does the CCW mean counter clockwise, CW clockwise
and if it does how would you verify this via a meter? Any help would be
greatly appreciated
:scratch:
greatly appreciated
:scratch:
Hi bugeyes!
You got the CCW and CW right. The third terminal is the viper. When you turn the pot fully CCW, you should measure close to zero ohms between the viper and the CCW terminal. Between the viper and the CW terminal you should then measure the full pot resistance. Turning the pot fully CW will give opposite results. Good luck!
