• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
B&W speakers,custom CNC enclosure speakers,radial horns
B&W 805S and center HTM4S speakers + 4 massive wood stands ......... 2300euro.
It is a scratch on the side of 805S, unfortunately.
They don't have more than 30 music hours.I bought also the 804S for a full B&W home cinema but my priority was changed.In the past,most of the time I was listen on 804S.That's why these speakers have a few hours of music.They came in pairs with consecutive numbers.For other high resolution pictures just let me know.
Original boxes.All 3 speakers are in ABSOLUTELY MINT condition except the scratch.
https://picasaweb.google.com/felixanex/NewFolder602#
Custom CNC layers for various types of speaker enclosures.
Depending on your ideea of how do you want to look your speakers,we can cutt the layers for you.Here are a few:
https://picasaweb.google.com/felixanex/NewFolder10#
https://picasaweb.google.com/felixanex/Incinta#
https://picasaweb.google.com/felixanex/Incinte#
MiniNautilus for a medium home cinema.
-93db spl
-110Hz-21Khz
-50W nominal power
-nominal cone displacement 4mm
-8 ohms impedance
The design is similar with B&W Nautilus.
Many shells is available on custom colour.Also the mold is for sale and you can made the shells yourself.
Custom CNC wood horns,1" and 2" exit horns.
https://picasaweb.google.com/felixanex/Horn#
This is a pair of 1" exit horn,built from high quality birch plywood.
The funnel shape of a conical horn can be, exponential, hyperbola, tractrice or variations thereof. The gain of the horn depends on the form, so that the ratio distortion / efficiency is A MUST to obtain the smallest compromise. I go for a hyperbolic curve, with the lowest distortion and highest efficiency compared with the types listed above.
I tested with TAD 2001 and have a really good responce.
I wanted to give them a vintage look and the finishes was maded with Danish Oil and french furniture wax.
The 2" exit horns will be also available soon,with or without finishes on custom order.
Also only parts can be available.
More pictures here:
