AVI S 2000 MD - looking for schematic
I have this old TDA1541A-based DAC lying around and hope someone is able to share its schematic. Here are some pictures.
And can anyone explain why there are two inputs, marked 5V and 1/5V?
S/PDIF standard voltage is relatively low at around 0.2V, with a maximum of about 0.6V
Some motherboards output S/PDIF at very high TTL Logic levels, which can go as high as 5V
You could use any TDA1541 with Philips "SAA chipset" schematics - that particular DAC differs in a way that it has a transistor output stage.
