..well kinda Power Supply Design..
Id like to run my Vaio laptop for longer than an hour off-grid and thought an SLA battery would work. Im going to get a car adapter and am not sure what voltage battery to use. The stock AC adapter supplies 19VDC(smps so regulated correct?) yet the car will only supply 13.6 to the car adapter. So will a 12V SLA battery work or should I add a 6V in series for 18V? I dont know if the DC-DC adapter acts as an inverter so that if the cars voltage drops below 12V, it will still supply power.
amt
amt
If the adapter is for use in a car you will have to supply it with the same voltage as the car does. Not more.
I believe the laptop needs 12VDC to operate but no vehicle Ive ever owned actually puts out 12VDC at the lighter or aux. power outlets. My Subaru puts out 14.4VDC. Vanagon 13.8.
I would think that the adapter has voltage regulators in it and they usually need an extra few volts to operate - hence my 18VDC question. Maybe not for smps. Dont know.
So will a straight 11-12VDC from a battery operate the adapter?
amt
amt
You can buy this:
http://www.xantrex.com/web/id/245/p/1/pt/31/product.asp
or
These
http://info.igo.com/mobility/datasheets/everywhere85_DS.pdf
which Radio Shack sells versions of, uses a TIP to set the power connector, voltage and polarity of the adapter. It works well.
or
These
