Just wondering if anyone has any experience with this PCB layout program. It looks like it has been around for a long time but a search of this forum didn't turn up much information about it.
AutoTRAX DEX-PCB Designer
It seems to be a capable application so I'm curious as to why someone might have tried it but decided not to use it.
AutoTrax was originally the name for Protel's PCB editor. If you're up for some nostalgia, try running AutoTrax under a DOS emulator, such as DOSBox. It's free!
Protel Autotrax - low cost PCB CAD
I grew up with this stuff. For the longest time I rarely touched the mouse under Windows versions of Protel, as my original DOS machines had no mouse, so _everything_ was done by the keyboard. Want to place a track - PT does that. PS Place String, PV Place Via. EMG edits polygon pours, etc etc. It's mostly muscle memory. You move around with the cursor keys - arrows move one grid position, numeric keypad moves ten. + and - (numeric pad) changes layers, page up and page down zooms in and out. Once you got the hang of it, you could build boards _fast_.
What made that technique painful was mixed technology boards. DIP was fine - 50 mil grid, pads on 100 mil centres. SOIC just halved that, with 50 mil pitch and 25 mil grid. Then you put a component on with 2mm pitch, and everything falls to pieces. That's why they invented mice, I think.
Ah, yes, the transition from DOS to Windows. I was a little stubborn in the beginning until I realized that resistance was futile.
The advertisement for the current Windows version of DEX-PCB is full of hyperbole so if it is as good as they say I was just curious as to why I never heard of it. I guess I could just install it and try it out. Or not. 🙂
