i want to use a mono sub amp with wireless remote .
how should i wire these ?
they are nominal 4 ohm each
i have 8 i want to use to rumble an upstairs floor under a couch
thanks
thanks
To be on the safe side I think they should be wired 4-4 series then parallel for an 8 ohm nominal. It's better to give your amp an easy load to push.
I agree, definately. Wire four of them in series and the other four in series as well, then wire both of those sets to each other in parallel.
