These are the items for sale. I’m cleaning the closest which long over due. I hope you will enjoy these items as much as I did. E-mail me at aprintis@comcast.net if you have any questions. I have an excellent rating with Ebay: http://feedback.ebay.com/ws/eBayISAPI.dll?ViewFeedback2&userid=aprintis&ftab=AllFeedback
Shipping charge will depend on where you are, so contact me with your address, and I’ll e-mail you the shipping charges (USPS). Payments are done via PayPal. E-mail me if you want pics to a specific or group of items and I'll send them to you.
Eclipse’s 37601 line driver. It is meant to be used with the head units of 8053/61/62 models, but you can use it for any head unit and step up the head unit’s voltage times 2, but it will be unbalanced. Unless the Meaning, if your head unit puts out 4; then, the output would source unit is 8, then the BLA can step up the out put voltage to 16 balanced be 8 unbalanced. $35
Here are some links:
http://www.cartoys.com/cartoy/pdfs/Eclipse_cd_manual.pdf
http://www.diymobileaudio.com/forum/memb...daptor-bla.html
Phoenix Gold’s Xenon 400.1 mono block amplifier. This amp has been rock solid under my very good condition , and I can guarantee it to be not DOA. On the upper top edge and front surface, there’s some light scratches, not major one. Missing on this unit are the front rubber covers, but this will not deter its performance. This amp was used to run my sub woofer. $75
Here are specs and a link:
• High efficiency (greater than 80%) Class D Operation
• Buffered RCA full range thru output
• Remote Monitoring Display (RMD) port
• Low Pass Level control ready (LPL-44) 400W x 1 (4-1 ohm)
• Xe.flow™ variable thermal feedback controlled fans
• Xe.tune™ 24dB Linkwitz-Riley low pass & subsonic filter
• Xe.load™ optimized for any impedance load
http://www.soundbuggy.com/Eric/Car Audio/phoenix_gold/xenon/x100_2/index.html
One Alpine PDX 4.100 4 channel 400 watt Digital Amplifier. The amp works great. The overall condition of the amp is good with some scratches and missing one circle cover. All 4 special speaker wire connectors are present. $200
Here are some specs:
100 watts RMS x 4 at 4 ohms (100 watts RMS x 4 at 2 ohms)
200 watts RMS x 2 in bridged mode (4-ohm stable in bridged mode)
4-channel car amplifier
CEA-2006 compliant
stackable installation design with front-panel controls
variable high- and low-pass filters (30-400 Hz, 12 dB/octave)
quick-connect speaker connectors
Class-D amplifier design
MOSFET power and output stages
fuse rating: 30A x 2
10-3/16"W x 2-1/2"H x 8-7/8"D
Another second Alpine PDX 4.100 4 channel 400 watt digital amplifier up for sale. This amp works great. The overall condition of the amp is very good with small scuffs and missing one speaker connector. The four connector can be had by another auction for $10-12. See specs from above. $200
Selling 2 Audison’sLRX 2.250 2-ch 420 watt amplifier up for sale. If you’re looking at this; then, you know a thing or two about Audison’s quality. The amp works great. The overall condition of the amp is in excellent condition. Another amp I enjoyed owning. I’m showing the amp working and it will complement your system. See spec from above except 2 x 120 Watts @ 4 Ohms, RMS Output 1 x 420 Watts @ 4 Ohms, 2 Ohms. $210 each
Here are some specs and a link:
• RMS Output 2 x 80 Watts @ 4 Ohms
• RMS Output 1 x 220 Watts @ 4 Ohms
• 2 Ohm Stable
• Bridgeable 2 / 1 Channel Output
• High Pass Crossover
• Low Pass Crossover
• RCA Input
http://www.audison.eu/xml/products/pdf/audison_support_manuals/LRx/discontinued/eng_lrx2manuale.pdf
Pioneer GEX-P900XM receiver, it comes will all the cables, short attenna, wire harness, and instruction manual. Can be used with all of Pioneer's recently made head units. $35
# XM DIGITAL SATELLITE TUNER FOR XM-COMPATIBLE PIONEER STEREOS
# MODEL: GEX-P920XM
# 2-MODE CHANNEL SELECTION
# WITH TEXT DATA
# 24 BIT D/A CONVERTER
# IP BUS IN/OUT
# ANTENNA CABLE: 16.25-INCH
# DIMENSIONS: L: 6-3/16", W: 7-1/16", H: 1-1/16"
Tru Technology’s B-2110 2 channel 400 watt amp. What can I say about Tru Technology has been fantastic and reliable amp. The amp works great. The overall condition of the amp is in very good condition with slight scratches on the surface. Another amp I enjoyed owning. I’m showing the amp working and it will complement any system. $275
- (8) ON® TO-3 Metal Case Output Devices for optimal performance & reliability
- 12dB Hi/Low pass X-over (50Hz ~ 500Hz)
- 1 Band Quasi-Parametric Bass EQ with variable Bass Boost
- Remote Bass Control (optional)
- 4 Gauge Power/Ground Input
- 8 Gauge Speaker Wire Output
http://www.trutechnology.com/products/billet/billetseries001.htm
One Phoenix Gold metal logo. The logo had been laser cut and professional done. There is two. One silver and the other is black to outline the silver one. It does need to be sand blasted or steel wooled. A little elbow grease is all it needs. I will include the special type of Dome Head & Square Neck bolts and nuts. $20
Eclipse baseball cap. Consider this new because I never have used it. $12.50
Illusion Audio’s LM6 6.5 inch mid-bass drivers. The speakers performed great. They come with gold plated screw down speaker wire terminals -quality. Smooth sounding speakers, but the speakers will come without covers. $55
Other types of original owner’s manuals: Audiocontrol EQX, Eclipse 5031, Eclipse CD8445, and Diamond Audio HEX component set. $7 each
CEA-2006 compliant
• 2 Ohm Stable
• RCA Input
# MODEL: GEX-P920XM
# WITH TEXT DATA
# IP BUS IN/OUT
