To make some room... I will sell some units for projects that I won't build:
Audiotechnology 15E Flexunits Sub/woofer. VERY GOOD CONDITION
T/S parameters from Dayton Audio Test System: DATS V3:
Re 6.008 [Ohms]
Fs 22.61 [Hz]
Zm 37.73 [Ohms]
BL 16.59 [N/A]
Qms 3.361
Qes 0.6365
Qts 0.5351
Vas 219.4 [liters]
L10k 0.5365 [mH]
n0 0.3799 [%]
dBSPL 87.9 [1W/1m]
Ms 205.2 [grams]
Cms 0.242 [mm/N]
Re 6.008 [Ohms]
Fs 22.61 [Hz]
Zm 37.73 [Ohms]
BL 16.59 [N/A]
Qms 3.361
Qes 0.6365
Qts 0.5351
Vas 219.4 [liters]
L10k 0.5365 [mH]
n0 0.3799 [%]
dBSPL 87.9 [1W/1m]
Ms 205.2 [grams]
Cms 0.242 [mm/N]
Do these have the standard 77 25 10 coil setup or different for more travel? i see surround is different.Audiotechnology 10C77 Flexunits woofer
I have to check it but I will reply and n MondayDo these have the standard 77 25 10 coil setup or different for more travel? i see surround is different.
T/S parameters from Dayton Audio Test System DATS V3:
VC 1+2 in parallel
Re 2.15 [Ohms]
Fs 33.85 [Hz]
Zm 32.54 [Ohms]
BL 11.32 [N/A]
Qms 4.53
Qes 0.3205
Qts 0.2993
Vas 37.64 [liters]
L10k 0.2949 [mH]
n0 0.4342 [%]
dBSPL 88.48 [1W/1m]
Ms 89.88 [grams]
Cms 0.246 [mm/N]
VC 1+2 in parallel
Re 2.15 [Ohms]
Fs 33.85 [Hz]
Zm 32.54 [Ohms]
BL 11.32 [N/A]
Qms 4.53
Qes 0.3205
Qts 0.2993
Vas 37.64 [liters]
L10k 0.2949 [mH]
n0 0.4342 [%]
dBSPL 88.48 [1W/1m]
Ms 89.88 [grams]
Cms 0.246 [mm/N]
