Hello guys, with pleasure I announce that our new facebook page is online for the sale of audio cables for various needs. Soon the official website will be online. the philosophy of audioleo is to offer cables that are difficult to find in large manufacturers(like various kind of dual head usb cables), at a very affordable price. at the same time, however, audioleo uses cables from leading manufacturers in the sector with respect to the specifications of the use for which they will be used, in particular for USB cables. if you want we are honored if you take a look at the page.
we are at the beginning so we apologize for the few products on the list, but slowly ... they will increase. anyone who needs custom cables can send an email to audioleo@gmail.com thank you
thank you so much and stay tuned!
Audioleo - Home | Facebook
Some of audioleo cables :
Ortro standard edition
Ortro standard edition is a dual head USB cable. It therefore has a type B connector on the peripheral side to be connected and two type A connectors on the PC side (or streamer etc.). This cable gives therefore the possibility not only to make the data and the current travel on two separate and individually shielded cables, but also to be able to supply the peripheral to be connected, generally a dac, a "clean" power supply through the use of a an external power supply. Unlike many very expensive cables, Ortro uses USB 2.0 certified cables and therefore complies with the protocol specifications. Technical features Data cable � 28AWG (data) and 26 AWG (power) section wires � copper braid shield and aluminum foil. � tinned copper conductor. � Polyethylene insulation. � twisted pair (two cables twisted together). � 90 ohm impedance � gold plated connectors � black nylon sheath. Unlike the upgraded version, it uses two identical data and power cables. The cable is sold with a technical card for maximum security of having a product that meets the specifications for its intended use.
fallout 3 electron charge pack
