Audiolab 8000s Fault
My 8000s (UK made "F" serial number) has recently developed a fault in that there is a momentary total loss of sound on both channels on the AUX channel (used with a trichord vinyl preamp). The sound comes back fine after a second or so. The muting led does not come on during the fault. Other than this, the amp is perfect. I have not heard this on any other input, but then I only really listen to vinyl.
Has anyone else come across this?
Many thanks.
Hola Pipomantis :
Tengo tambien un 8000S y me ocurre el mismo problema, tanto en la entrada de aux. como en la de Cd, se oye bien, pero de cuando en cuando se enciende la luz de standby y no se oye nada, dura aproximadamente unas milesimas de segundo.
Lo he llevado a un taller especializado para que lo miren. Cuando lo sepa te dire alguna cosa, o si tu ya lo sabes, dimelo. Gracias.
Hello Pipomantis:
I have a 8000S and was also the same problem occurs in both the aux input. as in the Cd, you hear it, but from time to time you turn on the standby light and no sound, lasts about a thousandth of a second.
I've been to a specialist to look at it. When I know I'll tell you something, or if you already know, let me know. Thank you.
