hi
i am working on a 2ch Audiofonics ADF-241 amp and two of the outputs on one side gets very hot and the amp draws alot of amps and the power light starts to link .i took them out of the board and tested them they read ok.i try the amp without the two outputs and it seems to be runing fine with no stress.i test the transistors and resistors in that area they tested ok with my mulit meter this amp also has two little boards at the front of the outputs one on each side it has SM parts on it.here are some voltages i took when i remove the two outputs
ALL TEST WAS DONE WITH BLACK LEAD ON GUD TERMINAL
KIA494AP(PWM)
PINS
1=2.5
2=4.9
3=.0
4=.1
5=1.5
6=3.5
7.0
8=12.6 to 12.8 not stable
9=4.7
10=4.7
11=13.2
12=12.5
13=4.9
14=4.9
15=4.9
16=.8
4558d next to the pwm ic
pins
1=1.3
2=10.5
3=5.9
4=.0
5=.7
6=4.9
7=1.2
8=12.3
from gnd to center of fets 12.8 on all four fets
''''''''''''''''''''''''''first legs 4.3 on all four fets
''''''''''''''''''''''''''third legs.0 ''''''''''''''''''''''''''''''
30.5 on the center pin
29.7 on the next one
and from gud to center of outputs 31v on some and 32v on some
any idea what could be the problem???
thanks
KIA494AP(PWM)
PINS
1=2.5
2=4.9
3=.0
4=.1
5=1.5
6=3.5
7.0
9=4.7
10=4.7
11=13.2
12=12.5
13=4.9
14=4.9
15=4.9
16=.8
pins
1=1.3
2=10.5
3=5.9
4=.0
5=.7
6=4.9
7=1.2
8=12.3
thanks
problem found
hi
i found four 16v caps 100uf leaky in power supply area and a broken track to a transistor d6ook in the output section amp work ok now
thx
hi
thx
Hi Ian33 could you tell me please the part number this amp uses for the power supply i think they are fets like Irfz44n or something like that, and please tell me the part number of the fet/transistor for the amplification stage, thank you so much for your help
