Audiobahn amp turns on briefly and turns off
I have an Audiobahn A8000T amp. A co-worker told me it could be the diode, so I replaced that, and tested it. It didn't change the results and the MOSFETs would actually catch fire. I noticed a few cracked afterwards and replaced them. Now, the amp will turn on (no more fire 😎) but it will only stay on for a second or two. It doesn't go into protect mode, it lights up, and the fan starts rotating, only for those few seconds though. Any thoughts on this?
I replaced all 8 of these MOSFETS on the board.
Check the output dc offset of the amp. Connect the DVM and then, power it ON.
Gajanan Phadte
In my experience it's not a good idea to power up a car amp when it's shutting itself down. They quickly destroy themselves. I usually test output transistors for shorts with no power applied first. Usually larger amps like this are driving subwoofers and the outputs fail hard from the heat.
