Audio test gear (CLIO alternatives?)
I have some work coming up that's going to require some spec testing. I want to be able to grab a frequency response graph, THD measurements, SNR and phase response from an audio circuit. That audio circuit may have a small amount of latency. I'm a mac user, so anything that is USB based would be ideal. A PC-based system would be preferable since I don't like having heaps of heavy gear when a small interface and some PC software can do the job.
After doing some research, I came across the CLIO. Are there any alternatives to the CLIO? Any that are mac compatible? Are there any hardware only solutions that are comparable in price?
Thanks guys
Options
Its a bit pricey but Praxis can do all you might need and a whole lot more. Its primarily speaker oriented, like Clio but structured like a network analyzer so its more flexible. A recently added feature allows mixed mode testing (digital source, analog response) but its untested. With a mike its under $1K I think.
http://www.libinst.com/index.html
Spectra does a lot as well but is less well setup for speakers. The web site is particularly opaque and klunky.
http://www.soundtechnology.com/Instrument.html
RMAA may be all you need and its free. I have used it to analyze the performace of FM modulators with iPods for example.
http://audio.rightmark.org/index_new.shtml
-De,mian
