Hi All
I'm designing something where the audio signal can go through either a copper trace on PCB or a solid plate of copper (easier) 32mm*32mm*1mm.
Would there be any negative outcome to using the solid copper plate as signal in/out and ground path?
Kind regards
Kind regards
It depends on what you are connecting to it. For RF a copper plane makes a good ground because it has low inductance. Audio doesn't really care about inductance but it does notice resistance - you need to know where the ground currents are going. That is why audio usually uses star or bus grounds.
Thanks DF96
I can then assume that I can do the following as nothing will be affecting the signal negatively?
It's part of a balanced ladder type attenuator.
Here is the final design.
Not all audio (mainly DIY), most professional audio and other audio (comms etc) has ground planes and ALL sensitive analogue PCBs (in fact all analogue)are multi layer with ground planes. The star refers to a star point where a signal ground is joined to a power ground. in fact it is only on here and other such sites that I see the spiders legs style grounds, everywhere else it is generally a ground plane (except the cheapest of the cheap designs).
And in todays RF rich environment a ground plane is your friend.
0.3mm (0.012") trace (standard for DIY and basic designs)
2 layer with ground:
Lo 6.8nH/cm
Co 0.46pF/cm
4 layer with ground:
Lo 4.7nH/cm
Co 0.66pF/cm
As already mentioned there will be capacitance between the planes. Also the signal-in plane and signal-out plane are close together and not shielded by a ground plane so there will be some capacitive coupling between them. Signal traces (instead of signal planes) will obviously have very much less capacitance, especially if they follow different paths and only cross ocasionally. For low value resistances in the attenuator the capacitance will probably not matter.
- Design & Build
- Construction Tips
- Audio signal through a trace or a solid plane.
