Is this my best bet for an under $100 function generator?
REK RAG101 Audio Generator Function Signal 10 to 1Mhz - eBay (item 300371534115 end time Dec-26-09 21:26:52 PST)
For a current project, all I need is a 1000 Hz sinusoidal signal are there any cheap/free alternatives out there that might work for me? Should I just spring for one of these to play with? What do I do about the 220V supply required (I'm in the US)?
The free alternate is:
Burn a CD with test tones (tones are available from lot's of web-sites) play it back using a player that has a volume control.
You can also use your mp3 player or cell phone with the test tones Seedskater mentioned if low THD is not a major concern. Some cell phones are actually not that bad nowadays. The headphone output of HTC Touch Pro 2 has a THD+N of 0.034% @ 1KHz last time I measured.
If potability is not a concern, you can always use PC + free signal generator programs if you have good quality sound cards.
However you will need amplification in either case if you need higher voltage output.
Hi Dread Pirate,
If you want hours of pointless fun you could make your own.
Here is a thread on the one that I built -
http://www.diyaudio.com/forums/equipment-tools/153969-diy-8038-function-generator-problem.html
It eventually worked well.
Rob
Rob
Pointless fun is what it's all about, but that looks like work. I'm going to try the cd tone route for now, perhaps move on as the need arises.
I am aslo looking for a general purpose function generator, for audio mainly, but I think higher frequency could be useful for components testing.
I cannot decide if I should take some toy like this:
Digital Function Signal Generator 5 digit 0.2Hz-2MHz ap - eBay (item 280431888649 end time Dec-30-09 22:49:42 PST)
Or get a used old fashion professional generator (the ones without display)
Please advice. Thanks,
Davide
Davide
After frustrations with PC based sweep generators, I bought an old HP 209A. It can sweep cleanly. Everything else I use my PC. I capture the tones into files. Normalize them, clean up the start and stop, leaving me a library of known exact amplitude signals.
nti, multi-sine and sig-jenny all freeware.
- Design & Build
- Equipment & Tools
- Audio Signal Generator on eBay
