Audio Note Kit Power Transformer
Audio Note Kit Transformer. For DAC 2.1 kit.
I built the kit and have since created a custom chassis. This involved replacing this transformer.
In perfect working condition.
Unfortunately I do not have the current ratings for the taps, nor do I know the volt-amp rating for the transformer as a whole. It's just not in the documentation.
Approximately 3.75" tall, 3" wide, 4" deep (measured tip of tap on one side and tip of tap on the other side).
Comes with an integrated grounding wire.
Weighs quite a bit--maybe 8 pounds.
To give you an idea of current capability, here are the intended purposes for each tap:
  • 9-0-9: AD1865 DAC implementation, including voltage regulators. I estimate 2A minimum.
  • 8-0-8: 2x DC regulated 6922 heater supplies. I estimate 2 amps minimum.
  • 300-0-300: 2x 6922 Supply, tube regulated. I estimate .1 A minimum.
  • 6.3-0: 6X5 Rectifier + 6BM8. Estimate 4 amp minimum
Looking for $50 + shipping, which may be at least $20.
