audio note dac 1.1.x schematics
Hello , i would be very grateful if you can help me with audio note dac 1.1x schematics -
i bought dac used and after replacing stock caps with black gates and philips caps - there is
hum coming from digital board ( probably earthing problems ) .
I would be interested to know if anyone replaced jensen's pio caps with obbligato's premium's ?
Any feedback ? And last question : any experience to bypass obbligato's with
vitamin q pio ?
Many thanks in advance
Your not the first one to replace capacitors and cause problems to the amp, hum related...
Look for things your could have break or overheat
Look for + - sides of polarised capacitors you have replaced
Check the capacitance of your caps and the voltage requirements.
