Has anyone heard the Audio Nirvana super 8 in Alnico? I'm not finding much info out there other than one post that compares them favorably to Lowthers.
Has anyone purchased these, and if so, how do they sound?
Thanks!
Thanks!
Nirvana
I happen to have visited the factory where these speakers are made in Guandong, China.
wonderfull factory, and very good speakers, its a taiwanese factory and they know what there doing.
i would not worry about the Quality!
Greetings,
Arjen helder
Greetings,
Arjen helder
i too would be interested to hear what it as to offer...
davids dicks from commonsenseaudio told me he likes them better than lowthers...except maybe for the midrange but the super 12 cast frame were a better value.
12"castframe vs 8"alnico
I am also trying to decide which Audio Nirvana driver to pick, i am trying decided between the 12"cast or the 8" alnico. I have decided to go with the 2.8 cabinet. Can anyone advise the strengths and weakness's of these two drivers.Cheers.
the best would be to ask dick at CSA. i only have the 12 cast frame and this is my only fullrange so i cant compare. i have it crossed with a woofer at 300 hz and what i can say is that it alleviated the AN of some burden for sure compared to the single driver. i havent found a way yet to make it sound acceptably pleasant and natural sounding. but i feel there is alot of potential for this driver either fullrange or crossed. on some tracks it really draws me into the music though. for example "kill em all" sounds awsome.
hope it helps
hope it helps
super 12
i had a pair of SUPER 12 ....wonderful speaker for the price.
but now i hear SUPRAVOX....215 signature bicone. 🙂
Hello,
AFAIK the Qts of the 8"alnico is high so no horn driver,
very deep,
i used the normal 8" in my SAXOPHON and think
they sound in the right enclosure better than
Fostex 206 and a few Lowther,
for the money good driver.
my experience:
http://www.hm-moreart.de/23.htm
very deep,
my experience:
Thanks for that, i have decided to go with the Cast12"..i asked Dave he said the 8"alnicos sound smoother and sweeter at more moderate volumes but the 12's are more dynamic and handle louder volumes. Occasionally i like to pump my stereo so i am going with the 12's. Looking very forward to this project..should i make my cab's out of MDF or berch?
Thanks Again.
Thanks Again.
By "berch" I assume you are referring to birch plywood. You'd want to use that instead of actual birch since it will not have the irregularity of solid wood.
I used birch ply with my Super 12s and they sound great. I used 2 3" ports, although others have used the 6", which I believe is what Common Sense Audio is recommending to many folks now.
Thakyou! will do. My 12"castframes are on there way,should get them in a week or so, very excited🙂
did you make your enclosures of solid wood? i'm a little bit puzzled i thought people referring to birch always intended ply birch... also the guys at commonsense audio
opps sorry, meant ply. i am sure solid hard wood would be great but to expensive. My next question is what port option,AN recommend the single large port option but there is also the smaller twin option aswell. I have a valodyne non ported 1000w sub that handles the low frequencies lovely so am thinking the larger port would be the way to go cause it handles the low-mids better????
no no, it's me, i think i gave the reversed sense to the second phrase...
does anyone know if baltich birch, marin birch, etc differ so much? or just by what name should i call it in italy?
Speakers and shipping by Priority Mail International (6 to 10 days with online tracking number):
Super 15 Cast Frame: $680/pr
Super 12 Cast Frame: 420
Super 12: 370
Super 10 Cast Frame: 370
Super 10: 320
Super 8 ALNICO 580
Super 8 Cast Frame: 310
Super 8: 270
Standard 8: 240
Super 6.5 Cast Frame: 280
Super 6.5: 250
Standard 6.5: 220
These prices are for shipping to Australia in USdollars
It worked out at $523AUD for the 12 Cast Frames
Super 12: 370
Super 10: 320
Super 8 ALNICO 580
Super 8: 270
Standard 8: 240
Super 6.5: 250
Standard 6.5: 220
12"castframes
My 12" castframes are due in the next couple of days very excited..i have been trying to decide between the 2.8 cabinet or the 5.6 cabinet..has anyone got the 5.6 and what is the verdict?
Well, I'd be going as large as you possibly can. Two basic T/S alignments give box volumes of roughly 32ft^3 and 39ft^3 respectively and a trad. BR alignment is 27.8ft^3. The older approach usually yeilds far larger boxes than T/S vented alignments with the vast majority of contemporary FR drivers; the ANs are something of an exception, due to their very high Vas & quite high (rather higher than claimed) Q. So, of the two, the 5.6 would probably be the better bet, assuming you want to minimise the compromises as far as possible. Make sure it's well braced though.
Thanks Scott, did not understand most of that but i will go with the 5.6 cabinet then, i thought larger would be better.Cheers
You're welcome.
Right, of the two, the 5.6 would certainly be my choice; the AN 12in drivers need a huge box to perform optimally, so always go for the largest cabinet you can manage.
- Full Range
- Audio Nirvana Alnico?
