Hello folks!
I am new here and I want some guidance.
I want to build a mixer board that can:
The board should be made from the scratch. I can not use ready-made DSP kits or development board.
Kindly guide me in this regard.
Thanking in anticipation.
- Mix 8 analog audio signals
- Do some filtration
- Output the mixed and filtered signal on a single line.
siyal343
The problem here is where are You getting the mixing and filtration chips from ….
Even if You find a manufacturer whit the specs You need, he will sell You only thousands of them.
Take a look at for example Pioneer DJ mixers. They use a chip inside with 100 legs which does everything digitally inside.
Buy a digital mixer, it is cheaper unless You are a rich person and can pay for R&D to a chip manufacturer.
Maaco this is Hazam's partner they are students doing this for a thesis project this was already discussed in another thread...construction of 8 channel live digital audio mixer
As covered in the other thread, you're undertaking a huge project here. I'd consider switching to analogue, but adding some neat digital features (digitally controlled pots are a thing - can you make a board that looks analogue, but can also be controlled by an iPad?)
Chris
Chris
I suspected that, although I note they did not say so at first.turk 182 said:they are students doing this for a thesis project
A lot of reading would be the best place to start. How much reading would depend on how much they already know about digital audio (sampling, filtering etc.) and mixed-signal PCB design.
