I am looking for the diagram for analog audio puccini stettanta.
I have one on the table with an underlying problem and I need the diagram before dismounting it completely to access the underside of the pcb.
I sent an email to Audio Analogue but no answer and unfortunately, the diagram of Puccini settanta is very different from other puccini.
I don't have a schematic or service data but what is the issue? There were a couple of faults that required service, according to some owners. A common one was failure of the standby power supply (The amplifier would not start at all) and required a replacement supply more than once.
If I tell you that the insulators of the pinouts of the TO3 have melted so much the amp has to heat up before failing, that gives you the state of the device 😲 😵 🤣
BBQ inside 😁
BBQ inside 😁
