Audio Alchemy DST cable power supply
I posted this question on rec.audio.tech, but given the low signal-to-noise ratio there I"m sure I have a better chance for an answer here. 🙂
I misplaced the power supply for my Audio Alchemy data stream transceiver (DST) powered digital cable. I have the "owner's manual" that came with it, but it doesn't discuss the power requirements.
Can anyone describe for me the connector (1/8" mini phone plug?) polarity and voltage?
Thanks in advance...
I only just noticed this while looking for a data sheet (manual) for the same model DST,
the power supply is 12VDC @ 150ma and though it uses an 1/8" plug it has three contacts which measured with no load +16.5v tip, -16.5v middle, ground bottom. The supply has an address of mfr Engineering Design and Sales, Danville, VA 24541. Good luck.
If you still have the unit any chance you could scan the data sheet for me?
-Lance
