Audio Active Filter
Hi all,
I have to make an active audio filter with the following specs:
- Low-pass < 200 Hz
- Band-pass: 200 Hz - 2.0 kHz
- High-pass: 2 kHz- 20 kHz
Which type do you suggest? I thought about Bessel.
Is UAF42 universal filter suitable and good in terms of noise for a quality audio application?
I have no problem to find any IC from Analog Devices, Burr-Brown (TI), National Seniconductors and also any kind of passive component.
Any suggestion will be very appreciated.
Milo
