I have not Built these speakers yet but they look really nice
http://home.hetnet.nl/~geenius/Auriga.html
the URL: http://design3d.host.sk/Hi-Fi/Audax/kls9.htm seems don't work. Can you send me that project to mail: risci@softhome.net
btw, http://home.hetnet.nl/~geenius/Auriga.html looks fantastic, but expensive 🙁
r!sc! said:the URL: http://design3d.host.sk/Hi-Fi/Audax/kls9.htm seems don't work
That's the correct link, and it has always worked for me. Maybe you have an old browser?
Audax french distributor's site
http://www.e44.com/leskits/audax_home210.html
http://www.e44.com/leskits/audax_home170.html
http://www.e44.com/leskits/audax_divers.html
God i want those Auriga's from humble homemade hifi soooooo bad, if only i had 1000 dollars to throw around
c'est la vie
c'est la vie
Audax 828 Kit
I have a PDF file for the Audax 828 kit which I've built but I can't post the file for you guys......so drop me an email and I'll send it that way. A lot better kit than the ones above!
Cheers
Keith:😉
Cheers
Keith:😉
Beware of the kls9!!! This design is, at least, sloppy! The crossover is inadequate for higher level listening as it didn't protect the tweeter from entering in its resonance region at levels too high for it and the tuned port is liliputian creating nasty compression inside the cabinet with the well known effect! The drivers by themselfes are good (I still work with them with very good results) but this design is widely inaccurate.
I much prefer keeping the 210 below 400 or 500 Hz and crossing the 025 no lower than 2 or 2.5 kHz, so the answer is? THREE WAY!!! At least, it works for me, but I think that's not the point here.
Just keep away from the kls9...
I think I would go with the Auriga if you want a completed, well documented, full range project. The Focal tweeter will not be given but this is for sure a good unit. You will encounter beaming effect of the high frequencies since the 7" is a little bit large for diffusing 4kHz but the HDA cone is light and well damped; it should sound just right, but only at the sweet spot and with some loudspeaker toe-in... You could also look for an HM130Z project if you want bookshelfs or little floorstandings.
Good luck!
Good luck!
Re KLS9
Hi Zappa,
Regarding your comments about the KLS9 design being a poor two way, do you have a good three way design using the HM210Z12. I'd be keen to look at any design you may have had success with.
Cheers,🙂
Hi Zappa,
Cheers,🙂
We will not doing threadjacking here, and since some people seems to own HM210Z, I think about starting a thread about a 3 way project based on this woofer family. I don't have a completed project to publish at this time, but it could be interesting to share developpement ideas during the progress of the experimentations 😎
Re: Audax 828 Kit
Please send me to: risci@softhome.net
Thanks.
phibes said:Hi,
Cheers
Keith:😉
Thanks.
- Audax project needed
