Hello all.. I am building the Audax KLS3, anyone know which dampening materials were used and how they were applied.Any suggestions for improvement in the XOVER very welcome.
It may help if you show people what you are talking about! The design can be seen HERE
I can't comment on the crossover mods other than to say use inductors wound with pure silver wire.
In my experience, the type of damping material in a ported design does not make much difference. Use what you can get hold of easily but I would suggest using a double thickness immediately behind each driver to minimise reflections back through the speaker cones. I cut it so that it stays in place through friction.
