At last, a cheap PCB mill
A post just arrived in my inbox with these 2 links in it:-
Mill&Drill - YouTube
Quick Printed Circuit Boards - Microsoft Research
These are about PCB milling using a Silhouette Cameo CNC paper cutter as the basic driver to mill PCBs in conjunction with a Dremel.
Cost <$300 US. Not absolutely ideal, but it seems to work. 300mm wide workpiece. Might need some care to do doublesided, but it drills the boards too. That alone is a boon, it opens up the possibility of thru-plated holes at home.
