Hi
I am new to diy hifi, and electronics in general! (i studied Geography at uni!)
In modding my cd player I am about to start work on replacing the standard clock. I have studied many of the forums but i need something cleared up.
>Are asynchronous reclocking and a separate low jitter clock completely separate concepts?
>further, if this is correct which configuration is best?
-old clock / no asynchronous reclocking (cdp standard)
-old clock / asynchronous reclocking
-new clock / no asynchronous reclocking
-new clock / asynchronous reclocking
Asynchronous reclocking is an easier option for me because i cannot source 11.2896 Mhz crystal osciallators in the UK! Whenever I find any they are out of stock ! 🙁
Ash.
Ash.
You can build a low jitter clock yourself, with your cd player's crystal and some circuitry around it, like the kwak clock
what's your cd player/dac?
I'm not sure about it, but assynchronous reclocking is of limited use for I2S. Yet to confirm
I have a few that im experimenting on:-
Mission pcm7000 (tda1541/saa7210 )
Philips CD471 (tda1541/saa7210 )
DPA little bit (Saa7350/ ym3623)
Philips cd723 (erm TDA1545 i think)
Probably will work on the Mission!
Ash.
Ash.
ash_dac said:Hi
Ash.
Hi
There is many options to roll your own clock
commercial mode on
www.TentLabs.com
commercial mode off
succes
