Mode is set at Master with 512fs
Output port is set at I2S 24bit
Input port is set at unused??? Why is it working? This is the only position that works (when power cycle is done between songs)
LGRP is normal
Bypass is disabled
PCM out to Metronome wires are about 4" long.
I2S from AA is 2', could this be the problem without the SCK connected? This was the factory cable length from the AA for this transport.
LGRP is normal
Bypass is disabled
You have five switches "in between" - right side. "Bypass" and "LGRP" are like that... I don't think is normal.
