Arta help needed.
Sorry for my englis.
What i want from Arta is to measure response at different frequencies on MT x-over but problem is with time responce.
For what reason the signals measured from the same position are not identical in star time?
attachment.php
This is 2800hz.
Time record function in ARTA is not for measuring delay, sound "flying time", acoustic center of driver or any other start time. It is for measuring waveform/shape of the signal, though there could be some cheap tricks available for aligning start time e.g. with trigger signal.
Semi-dual or dual channel IR measurement is valid for timing.
Thanks a lot!🙂
