[comment][/comment]Hello Forum!
This is my first post here - wooo!
I come to you with a problem. I have an Armstrong 625 receiver (I also have a 621) working 99% ok. The only problem is the balance. In the neutral point only left plays. As I go toward right left start fading, right nothing. When I am about 80% to the right, right starts playing loud (as it would play if it would be at that sport). I suspect since the unit was store in a damp area, the potentiometer is damaged (it also moves hard to the right than other potentiometers). How can I replace it? I look on the internet but I could not find any potentiometers for this specific units. I suspect is a common one. But I need to identify it.
Can you help me?
Ive attached a picture form internet, but it is similar to my unit (even tho this is 621, the part is the same)
Thank you!
Hk
Can you help me?
Thank you!
Hk
There are four dual controls + a function switch shown in your picture , one of them is the balance control ---yes ?
Just read off the value on the side of the control most old UK amplifiers/receivers show this like --50K-100K etc .
Forget looking for the exact replacement, I have lost count of the number of non factory original potentiometers that I have fitted to valve radios /old amplifiers , a small saw can cut down a shaft to the correct length as long as its a new one with a good track .
I don't have a schematic to hand yet that shows the balance control.
The volume control is a dual 100k log type. Balance conrol seems to be a dual 20k, taper unknown.
Armstrong 625 FM Stereo Receiver Manual | HiFi Engine
