I use a simple volume control from my streamer to my amp setup to adjust volume. The volume control has RCA input -> 10k pot -> parallel RCA outs. One output goes to a crown power amp to drive subs and the other RCA out goes to a 2 watt SET tube power amp.
I’m getting ready to insert a DAC (Denafrips Ares II) between the streamer and the volume control. The Ares II has a high output impedance (1.2k ohm). Should I switch out the pot in the volume control to a 20k or something else?
