have a bunch of these lighting fixtures but i dont know if they are usable, little dusty but seem to be intact inside the cases. hopefully someone with more knowledge about these can tell me.
http://www.geocities.com/staticvoid2001/capandign.JPG
http://www.geocities.com/staticvoid2001/socket.JPG
http://www.geocities.com/staticvoid2001/trans.JPG
has a 600v fuse, and the plugin looks to be either a 220 or 3 phase plug.
label says
watts 400
lamp type s51
hertz 60
volts 277
H.P.F.
pri amps 1.86
suitable for operation in ambients not exceeding 40C
use minimum 90C wire
lithonia hi-tek
tx 400s arw 277 sf hsg
597181
rj00675
05-24-88
usable or not can someone recommend a lighting setup for a psone projector.
thanks for looking and hopefully someone will know and share their thoughts.
label says
watts 400
lamp type s51
hertz 60
volts 277
H.P.F.
pri amps 1.86
lithonia hi-tek
597181
rj00675
05-24-88
That's a S51 coil and core ballast. It's suitable for use with the Ushio S400DD bulb. Only problem would be thr required voltage to run it. You can find those ballasts on ebay in 120 volt versions for 35 dollars.
thnaks for answering me
so is my guess right are these 220 or 3 phase?
reason i asked is i have like 20 or so of these.
any cheap options for lighting a psone pj?
They are 277 volt. Not sure if they are single or three plase. Hard to tell from the pics. As for cheap lighting, how cheap do you want to go? Some people are happy with buying a cheap used overhead projector that has a 360 or 410 watt bulb and stripping the light engine out and using that.
