Are these good specs?
I've been reading about screen circles here on the forum. Would over 4.7 per mm help correct that? The largest LCD you could use this with is a 14".
Fresnel Lens Type: Positive
Lens Application Infrared; Visible
Lens Geometry
Effective Focal Length (mm/in) 318 / 12.5
Grooves Per Millimeter (grooves per mm) 4.70
Lens Shape Square
Square Side Length (mm/in) 280 / 11
Thickness (mm) 2.30
Acrylic plastic lens, 1.491 index, 92% transmission
John
