I am change a Tw 6ohms for another with 4 ohms .
Is a good option 4ohms for SE Triode tube amplifier ?
Santiago.
Santiago.
Someones tell me , 4 ohms are not enough for 8 ohms output transformer.
And i am finishing my amplifier , and the tweeters are 4ohms.
I will be biamp the Tw with the 300B.
Try it, you can't damage anything. If you want, put a 4 ohm resistor in series with your tweeter for 8 ohms.
Steve
Steve
- Tubes / Valves
- Are enough 4ohms drivers for a single ended tube amplifier with only 8ohms output ?
