Hi everyone currently repairing an Arcam delta 290
I channel was down blowing mains fuse ,replaced the fets with new irfp240,fixed no more dc problems ,i get music but when i try and turn
up the amp the sound is distorted,,i also replaced pre driver transistors......
Bias is correct ,altering it makes no difference,changed preamp chip also still same....
Thanks to anyoone,.
Thanks to anyoone,.
check the Vbe voltages of all the transistors.
If they are around 600mV+-50mV, then that probably indicates they have not been damaged.
The exception will be any protection transistors which may run with Vbe <<=400mV
