Does anybody what the crystal frequency of the Delta 170 Cd is?
The crystal is covered with heatshrink and I do not want to remove it unless absolutely necessary. As the SAA 7000 series chips are used I would guess the frequency to be 11.2896MHz, is this correct?
I am toying with the idea of upgrading the clock circuitry, hence the questions. Contacted Arcam directly but so far no joy.
A circuit diagram or even a manual would be much appreciated as I bought mine second hand and recieved only the transport and remote.
Thank you
Thank you
Send me a PM via the admins. It has 11.2896 MHz clock. Please remove the crystal and place a Tent clock module, you'll like the transport even better ...
CDM1 Spareparts
Hello
I take a chance here and direct myself to you Jean-Paul as I could not mail you I found an old thread where you said the following:
"Although I thought it was impossible it seems I found a source for lasers for the CDM 1. Waiting for their answer now. Their system says it is still in stock...
Jean-Paul "
What happend is a proud owner of a CD80 wondering ?
/ Per
Hello
Jean-Paul "
/ Per
Hello Per, I recently stated in another thread that I am still waiting meaning that they will probably never arrive. But it appeared I had some spare lasers in stock that I didn't know of so I can repair my own CD80 ( when I find a nice one 😉 ).
Somebody sent me some pics of his modded cd80. A photo of the transport looks like a cd1mk2 to me (hard to tell, it's modified). So some cd4 lasers should fit.
The pic is too big to post here..
GuidoB
Of ben ik nu gek?
GuidoB
Of ben ik nu gek?
From what I read in another thread CDM4/31 lasers should work in a CDM1 Mk II. I once replaced a worn out CDM 1 laser of a CD 880/882 for a CDM4/XX ( sorry I really forgot which one ) laser and it worked. I just looked in my small stock for one that looked like the CDM1 one and mounted it. Never had a good feeling about it but it worked like it should do.
As I am not really into CDM1 I am not *very* familiar with it so don't try this at home. My info is from quite some years ago and it would be a shame to damage your precious CDM4/XX because of my vague info ....
According to Bartek CDM 4/31 has the same laser as CDM1 Mk II. I can tell you I wrote that line down !!
- Digital Source
- Arcam Delta 170 CD Transport
