Hi all,
I have a Arcam avr 200 that has blown a amp2 card big style???
the card has the words 1725-561A-0002
section C issue D
pcb AL020C AMP2
is there any way to replace this and were is the
best place to get hold of
Many Thanks Steve
If you check out other threads on the AVR200, you will find advice as to what may be the cause. Like most things, these are repairable, and parts can be obtained from various suppliers. If you have access to suitable test equipment (at least a multimeter), and can work safely on electronic equipment, you may want to go this route. I doubt that a circuit board c/w components would be available, other than from a scrap receiver, and, if it were, the price may well be uneconomically high!
