Dear Sirs,
I am looking for opinions from people who have used the TL783 regulator.
I would like to build a 60V power supply.
Is the simple schema on the data sheet valuable?
Is there any method to improve noise rejection and to lower the residual ripple?
I intend to use the PS to power an audio preamp.
Thank you very much indeed.
Kind regards,
beppe61
Kind regards,
beppe61
the best way to lower the ripple voltage is to use a large amount of capacitance before the regulator. since you're dealing with high input voltages (assuming a max dropout voltage of 20V, so around 80V to get 60V output) the caps would be fairly large. you can improve the noise by bypassing the larger electrolytic caps and rectifier diodes with smaller value film caps. a properly implemented snubber can also remove a bit of noise.
BWRX said:the best way to lower the ripple voltage is to use a large amount of capacitance before the regulator. since you're dealing with high input voltages (assuming a max dropout voltage of 20V, so around 80V to get 60V output) the caps would be fairly large. you can improve the noise by bypassing the larger electrolytic caps and rectifier diodes with smaller value film caps. a properly implemented snubber can also remove a bit of noise.
Dear Sir,
thank you very much indeed for your extremely kind and valuable reply.
I would like to take advantage of your competence to ask you the following.
I need the 60V power supply for an audio preamp.
I have the opportunity to buy a Sorensen PS on ebay.it.
Do you think that a DIY project can approach the quality of that lab power supply (it is not that cheap, about 250 USD here in Italy)?
For my application the quality of the power supply is paramount.
Thank you very much indeed again.
Kind regards,
beppe61
tl783
If you want to really get the noise down you can add an inductor in series with the output of the regulator with a large capacitance down to 0v. I assume you are running at only a few hundred milliamps or less, so would suggest about 47mH to 100mH with say 470ufd as the shunt capacitor (larger the better within reason). This acts as a low pass filter and will not affect the regulation if you keep the resistance of the inductor as low as possible.
regards,
Steve
regards,
Steve
beppe61 said:I have the opportunity to buy a Sorensen PS on ebay.it.
I assume that you mean this power supply.
Here is the manual for that particular family of supplies.
Seeing that your preamp supply does not need to supply a lot of current, you should be able to make a good supply for less than $250. I made an adjustable voltage dual rail supply capable of about 0 to ±20V and up to about 5A per rail with LT1083 regulators for around $200 total (parts, case, connectors, hardware, etc.), but I went a little overkill with the components because I wanted to use it as a supply for a couple of single ended amps.
Your high voltage, low current supply wouldn't need too large of a transformer, which is where most of the cost comes from in good high power linear supplies. You'd probably want to look for a 120VA or 160VA transformer with 55VAC or 60VAC secondaries.
Following the basic circuit on the data sheet with a couple of tweaks will result in a fine supply.
Steve also made a good point about adding the inductor. Again, since this is a fairly low current supply you won't need a huge inductor to keep the losses minimal.
beppe61 said:Thank you very much indeed again.
Kind regards,
beppe61
You're very welcome 🙂
Brian
BWRX said:
Dear Mr. Bryan,
thank you sincerely for your very kind and valuable support.
I cannot figure out why I told you about an ebay buy.
Silly me.
Anyway, the Sorensen Power Supply I am thinking about buying is the same model as this one: http://www.used-line.com/c4914726s882-SORENSEN_QRD_60.htm
It can provide up to 60 V (my needed voltage) and 1,5 A, where my circuit needs about 0,1 A.
The price is 250 euro but maybe I can get a small discount.
It seems a great PS and I think that the ripple here should be pretty minimal.
I would be very interested in hearing your opinion.
Thank you very much again for your kind help.
Kind regards,
beppe
Italy
Re: tl783
Dear Mr. Hawkins,
thank you sincerely for your kind and really valuable suggestion.
Actually I need 0- 60V with a consumption of about 0,1 A.
The Power Supply is for an audio preamp.
The quality of the supply is paramount because all the noise will be available at the output and then amplified by the following power amp.
A battery would be my dream (or a virtual battery).
But it is not that convenient to manage.
If I understand correctly, you suggest to put a 47-100 milliH inductor just after the TL783 and then a capacitor of 470 microF.
Am I right?
The circuit is in A class, so it should draw a constant current from the Power Supply.
What about a simpler R-C filter maybe before the regulator?
If you know any great ready off-the-shelf power supply reasonably priced please show me.
Thank you very much again for your kind reply.
Best regards,
beppe
Italy
steve hawkins said:If you want to really get the noise down you can add an inductor in series with the output of the regulator with a large capacitance down to 0v.
regards,
Steve
Dear Mr. Hawkins,
Am I right?
Best regards,
beppe
Italy
250? For that?
Are you sure you don't want to try the schematic in the datasheet?
A 44000 uF capacitor bank will not cost you more than 40 euros, the IC costs itself about 5-6 euros and the transformer+rectifiers - 50 euros.
In total from 100 to 120 euros.
Why waste so much on a PSU, that in fact may not perform as equally as the IC? I'd try to understand you if it were a brand new PSU, but it's
second-hand. A preamp doesn't even need a PSU with current/voltage adjustment if you've tested it already and it works.
P.S.: if I were you, I'd buy a transformer, some Schottky rectifiers and the left over money from those 250 euros I'd spend on capacitors. 😀 😉
jackinnj said:TL783 is no longer available in TO-220
Are you sure? It says it's available in TO-220 and PFM (surface mount) on ti's site.
Ah I see. It says it was discontinued on mouser, but they still have stock of the TO-220 TL783 manufactured by NJR.
beppe, it would probably be cheaper and more rewarding to build the supply yourself. I also find that things you build yourself often sound better in the end as well 😀
The only product currently available in the U.S. is the TL783TER (the TL783CKC was the TO-220 version.) It shouldn't be difficult to utilize the TL783TER -- save for the fact that it has to be heatsinked with copper area.
You can "scale" the POOGE 5.51 regulator and avoid using an opamp by changing the transistors, resistor values etc.
tl783
Hi Beppe,
Yes, you should have a capacitor to ground from the output of the TL783 anyway. The inductor is then connected to the output of the regulator (junction between regular and capacitor) with another capacitor to ground after the inductor. All it is basically doing is adding a low pass filter after your standard TL783 regulator circuit. If it is Class A there will no change in current, so you could probably use even more value of inductance than I originally suggested without worrying about loss of regulation. With all power supply decoupling, it is good practice to use a quality Tantalum capacitor as smoothing, in addition to the normal electrolytic. Tantalums work better at surpressing higher frequencies. You can also add a couple of ceramic capacitors to get rid of RF noise if you wish. As far as I am aware the TL783 is still available in TO220 in the U.K, as I have only recently used one in a 100v constant current source circuit.
If you need any more advice please ask.
regards,
Steve🙂
Hi Beppe,
regards,
Steve🙂
Dark Harroth said:
> 250? For that?
Dear Mr. Harroth,
thank you for your kind and valuable reply.
Unfortunately here in Italy is not very common to find good deal on electronic equipments, even refurbished.
Yes. The list price is 250 euro (maybe I can get some small discount but I don't know).
I am tempted because it is variable from 0V up to 60V and it could be fine for powering some DIY prototype of preamps that I have in mind.
I am really interested in the TL783.
It is very convenient and it seems easy to use.
I am just doubtful about the residual ripple, that should be the minimal possible.
WOW. 44000 uF ! I thought that something like 2200 uF /100 V were enough. The circuit draws about 0,1 A at 60V maximum.
The price is very tempting indeed.
But the Sorensen appears a lab grade power supply.
Anyway I have not the specs.
Are you telling me that the TL783 based PS could be better performing that a lab grade PS?
I am doubtful about this.
second-hand.
But maybe built to very high standards.
I really don't know anyway.
I agree completely. The circuit worked fine with a rudimental PS but the output was not the last word in noise etc.
I have some problem in selecting the best parts for the PS (diodes and caps above all other things).
Caps, for instance, had an unbelievable influence on the sound.
I had a very old Mallory cap on hand and I liked it immensely.
As I said before, here in Italy is very difficult to find the best components and the price are insanely high.
Any suggestion will be very welcome and appreciated here.
Thank you very much again.
Kind regards,
beppe61
Re: tl783
Dear Mr. Hawkins,
thank you sincerely for your extremely kind and valuable help.
I will try to do my best.
Kind regards,
beppe61
steve hawkins said:Hi Beppe,
Inductors are indeed very often present in audio preamp (expecially tubed ones).
I think that their effects could be very remarkable in lowering residual ripple but they are more complicated than a R-C filter.
Are very much more performant than simpler R-C filters?
Good to hear that. No experience with tantalum caps.
It seems also available here from RS Components.
regards,
Steve🙂
Dear Mr. Hawkins,
Kind regards,
beppe61
I use a very large capacitance bank when powering my preamp. Nothing else. I've tested several types of capacitors from different manufacturers, and the worst imho (it also appears to be the most available) is Jamicon. Never buy those 😉 Btw, you can use a capacitance amplifier, that was discussed here.
And also I don't trust everything that's not bought new, especially after I bought a used kepco psu. A few hours after I had turned it on to test a self-made battery charger it sparked a few times inside it and the electricity got shut down in the whole apartment. So I lost 150 dollars.
And, tantalum caps produce noise and are used mainly in digital (i.e. PC) power supplies.
Dark Harroth said:I use a very large capacitance bank when powering my preamp. Nothing else.
You mean that you don't use any kind of regulation?
I think the at YBA they do the same.
Why don't you like voltage regulators?
Do you think they influence the sound in a negative way?
That is very importnat to me.
I record your precious suggestion.
Thank you. Actually Jamicon caps ar not that common in high-end products. This must say something.
I think it is a little too complicate for my taste.
I would like to stay simplest as possible.
That is a very important point.
I sometimes go to electronic fairs and there is surplus material.
I don't know what to do beacuse it is difficult to assess the real quality of the components.
Once I bought a lot of dried out caps.
It is my personal experience that capacitors are maybe the most important parts of a power supply.
They also influence the resulting sound of audio equipment in an unbelievable way.
Actually I did not believe it until I heard it.
Thank you for your extremely kind and helpful suggestions.
Kind regards,
beppe61
Used test equipment doesn't go to Heaven, it goes to EBay. Quite frankly, some of the stuff on EBay at the moment is "stems and seeds".
I don't trust single-chip regulators, because they add audible noise when I use a low-level signal source and have to turn the volume to the highest level. And making a hi-performance discrete design is a very time/nerve-costing idea.
In my two preamp projects I use capacitors, because preamps usually don't consume more than 100mA, and with a 88mF bank at each rail I don't hear any noise. Of course, this depends actually on the schematic used, but my ones perform well. 🙂
- Power Supplies
- Anyone who have used the TL783 ?
