Anyone used high voltage MKP1848 caps
In tube power supplies or for cathode bypass duties?
If so, what are your findings re their performance?
Thanks in advance.
i used them as cathode bypass , and driver load cap ( 100uf and 50uf) sounds better than a electrolyte but they so much bigger!! you can bypass the bigger ones with 100nf PIO or teflon to fine tune the HF , no bypass needs for smaller ones..🙂
