Hi all,
datasheet doesn't show this value... and it is key to calculate Zobel network... I'm tempted to try a zobel to see what happens, my amp is tube output set to 8 ohms.
thanks
paba
thanks
paba
wow, that's the highest L(e) of all published Fostex specs...
so with R(e) = 6 ohms and L(e) = 0.83 mH then the Zobel would be R= 7.5 ohms and C = 14.76 uF or 15uf for standard value.
It will be some time before I get a chance to try and report back.
Thanks ScottG
cheers
paba
Thanks ScottG
cheers
paba
paba said:wow, that's the highest L(e) of all published Fostex specs...
Thanks ScottG
cheers
paba
Your welcome! ..but the thanks should be going to member Zaph (..he is the one that did the measuring).
