I want to bevel the holes for my drivers. My baffle will be two layers 18mm each. I need to figure out the large dia after the hole is beveled. From that I will know how large the hole in the second baffle has to be so its smallest dia is the same as the large dia of the hole in the first baffle. The bevel will be 45deg. The goal is that both bevels will line up to make one large one when the baffles are laminated together.
