I had a membership here once but cant get back in after being inactive.
I need to download the service manual in this link.
If anyone can help, that would be great thanks.
https://www.vinylengine.com/library/akai/ap-005.shtml
I was able to download it. PM me you email.If anyone can help, that would be great thanks.
jeff
Same problem. My old login doesn't work. Would anyone be kind enough to download the manuals for this tonearm?
https://www.vinylengine.com/library/grace/g-707.shtml
There are Mk I and Mk II versions of the Grace 707 arm. The Mk I had bearing problems.
The Mk II had improved bearings and a decoupled counterweight, which was a rubber sleeve between the arm and counterweight.
Otherwise they are the same.
A friend of mine has bought an EMT 948 and are trying to get the instruction/owners manual and service manual from vinylengine. Unfortunately both his an my account has been deleted. Are anyone here able to help?
Mogens
Mogens
Nope, got booted off also after ten years of abusing their website.
However, I did find something regarding the 948 elsewhere.
https://audiocircuit.dk/downloads/emt/EMT-948-tt-sm.pdf
Thanks, at least he will have something to go on with this. Hopefully someone still has access.
Mogens
Mogens
Hi All,
I have succeeded in getting the manual from another source. With regards to the site, I don't see a problem in deleting accounts that hasn't been used for a long time. However, I do find it a little strange that one can't sign up again. Anyways, that's how it is.
Thanks to all.
Mogens
Thanks to all.
Mogens
I have been in the HifiEngine account for 4 years, and now I found that it has also been deleted. These two documents are needed by my equipment, can you help me? Thank you very much🙂
Marantz dr-17 user manual
https://www.hifiengine.com/hfe_downloads/download.php?marantz/marantz_dr-17_en.pdf
kenwood dp-2020 SM
https://www.hifiengine.com/hfe_down...wood/kenwood_dp-2020_3020_4020_service_en.pdf
kenwood dp-2020 SM
- Member Areas
- The Lounge
- Anyone here a member of vinylengine?
